Tuning wheel in SDR IOS on iPhone changes sensitivity when pressed
mikeatthebeach .
When I press the tuning wheel in SDR IOS on the IPhone I notice the receive sensitivity increase when Tuning wheel is pressed or tuned anyone else notice this? Using IPhone 8 Plus with SDR IOS and My Flex radio 73 Mike WB6DJI
I need help getting my Iphone X to work with SDR IOS.
When help vertically, I have multiple windows of the same thing and don't know how to move them off the screen. When I switch to horizontal, I then can see the panadaptor and I can key the PTT, but how do I talk over the iPhone? Do I need an external blue tooth mic? t have the latest SDR IOS. So I don't know what you mean by "tuning wheel' I have seen a horizontal slider that changes freq -but at a slow rate.0 -
They have a very good manual on how to use the program.0
The tuning wheel is a slider you refer That tuning wheel frequency slider generates more noise in receiver When held down Apparently it increases sensitivity when pressed Signals seem more clear , able to hear them better Thought it might be a program bug0
The SDR IOS manual helps you with mic settings0
Mike,
I do not notice any changes in sensitivity when operating the slider to change frequencies in SDR iOS (2.4.9 in the Flex at home, and iPhone X).
73 de Juan, NA0B
I believe that the pressure sensitivity is a function of the iOS operating system and not the SmartSDR iOS software. The pressure sensitivity is called 3D Touch, and, I believe it is available only on iPhones. It is not available on my iPad Pro, and perhaps not on any of the ipads. It is adjustable, however. Google for instructions on how to change the sensitivity.0
Talking about Receive Noise increase not Anything due to touch screen sensitivity 73 Mike0
I misunderstood your original post. I thought you were referring to the sensitivity of the control. I should have read it more carefully - Sorry!
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 376 SmartSDR API
- 9.2K Radios and Accessories
- 24 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 861 FLEX Series (Legacy) Radios
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 286 Shack Infrastructure
- 201 Networking
- 140 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
