DAX and RX streams question
Sergey KN7K
Member ✭✭✭
I have a question about DAX Control panel.
If I open more than one panadapter or add a Slice receiver,
I only see Slice A in DAX control panel.
While i can listen other panadapters , I just would like to understand the DAX control panel.
Could soneone clarify it for me, please .
Here is example below.
Sergey, KN7K
Sergey, KN7K
If you select a DAX channel on the slice B flag, you will then see that Slice B is identified as the source for that channel in the DAX control panel. You must select a DAX channel in the slice flag or nothing can show up in the control panel.
Ah, i did not realize i have to assign it on each DAX. Make sense.
Cool, Thanks a lot for a quick reply.
Sergey, KN7K0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
