6400 Mic connector wiring
Geoff AB6BT
Member ✭✭✭
I can't seem to find a wiring diagram for the Mic connector on the 6400. The text in the hardware manual states that for an electret mic that bias is applied to the (+) terminal. Is the (+) terminal the tip? A typical PC mic connector is wired with bias to the ring, of an 1/8" TRS, and the mic audio output is available on the tip.
So, if I plug an electret mic with that configuration into the mic jack on the 6400 will that work? Or do I have to build an adapter?
Unless I've missed something, there is nowhere I have found that explains this clearly.
Geoff
Geoff
Geoff
The current FLEX-6400/FLEX-6600 Hardware Reference Manual on pages 27-29 shows the correct
pinout.
http://www.flexradio.com/downloads/flex-6400-and-flex-6600-hardware-reference-manual-pdf/#
The Bias voltage will be on the Tip, when it's enabled.For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
OK, I see that, thanks for pointing it out. Somehow I missed that.
So, just to confirm, that means that a normally configured PC mic, with bias on the ring and audio on the tip, will not work.0 -
Geoff
Correct, I think a homebrewed adapter would be possible though.For real-time discussions
Right. I've got all the pieces so I'll build one. I just think it odd that Flex would use a non-standard configuration. I'm sure there was a reason behind the decision.
Thanks for your help.
73, Geoff
AB6BT0 -
Cheap, Cheap, Cheap! Plus they can charge $40 for adapter cables.1
I don't see how the wiring configuration would change the cost in any way.
And if people are unable to fab their own adapters then I think it is entirely reasonable to charge for T&M just like any other product.1 -
Totally agree Geoff. Many configs possible via the correct adapter.0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 949 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
