dual receiver setup Flex 6500
Gene - K3GC
I am attempting to set up the dual receivers on my 6500 so one antenna will point at ANT1 Tx1 and the other to be setup for ANT2 Tx2.
If I set slice A to be ANT1 Rcv and TX it works as set
If I set slice B to be ANT2 Rcv and Tx the TX will revert to ANT1
I am not alt all sure any of this makes and sense.
To restate i would like to have one slice set at ANT1 and the other automatically go to ANT2
The radio is set with a Hhx beam on Ant1 and a 40m vertical on ant 2
I hope this makes some sense to someone out there.
I know what I want to do but I fear i don't express it .
Thanks for your patience
Hi Gene...
Still getting acquainted with my 6600-M, too.
There's probably a better solution than I've got (that would be where the smart money is) and there are brains far larger than mine in the Community you can rely upon...but maybe the answer would be to create and save a profile for your desired configuration and load it when you start SmartSDR.
There may even be a way to make this your default profile when you start SmartSDR...but I haven't quite figured that out yet. At this point, I think I "get" about 2% of the capability of my 6600-M.
73, Ray - ND8L
The 6500 has only ONE SCU, so whatever you pick 'last' for antenna will be applied to all slices for receive. Basically one antenna for all slices even though you can have to 4 slices....
so you can not have two different slices on two different antenna at the same time
so your attempt to slice A on rcv ant1 and slice B on rcv ant2 can never happen
the 6500 hardware is not capable of doing what you want it to do.
Paul K3SF
Thanks Paul,
I sort of thought it would be something like that0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
