Remote Flex6600M Reboot Turn-On Problem if my 12V Supply goes off - How to Turn On Remotely ???
mikeatthebeach .
Question
Push Green Power On Button Remotely ?? Can not do that Remotely !!
Does Flex have a way to Turn back On again the the Flex6600M remotely with a
Control Line can turn back on remotely in case I lose 12V on back of radio
due to a power outage - etc ?
Have a Data Loggers Web Power Switch to Turn 12V Supply On & Off but
Once Flex6600m goes off and I lose 12V and not turn the Flex6600M back
ON again to boot up Flex6600M
73 Mike
Question
73 Mike
See page 24 of your 6400/6600 User manual. The "Remote Power On" jack does what you want. Use a Data Loggers relay to short this input to turn on the radio. Open it to turn the radio off.
Craig,
Great - that solves the problem !!
Thanks again
73 Mike
When opening the relay, does the 6400/6600 go through the "normal" shutdown process or does it simply disconnect power?0
The relay acts just like pressing the power switch. The radio does its normal boot-up and shut-down routines. You need to have 13.8V applied before closing the relay, and keep it on after opening the relay until the radio has shut down.0
- 650 The Flea Market
- 154 SmartSDR+
- 49 Aurora
- 964 Maestro
- 938 Genius Products
