Mac xDAX TX stream cannot get out of DAX TX OFF mode - 6600M WSJT-X
Roger Schultz
New to my new Flexradio 6600M and thought I'd start with FT-8 as I try to learn the ropes. Got xDAX and xCAT and Loopback - wsjt-x is decoding like crazy - stations I'd like to work if only I could transmit. I must be missing something obvious to turn on the output stream, but all experiments so far have failed. I'm assuming something to turn on DAX is necessary, currently I have DAX channel 1 selected - maybe some other switch to enable?? Any help appreciated.
Be sure you are using the 1.9 latest version. You also have to manually select the enable button on the main screen near the middle right I believe is where it is in the software to get it to transmit once setup.0
Well, turns out I didn’t look in enough places - the DAX turn on is in the TX Menu gotten through the multi-function knob at the right side of the FlexRadio front panel vs through the menu buttton. Once turned on, all worked fine.0
I thought you had already done that when you said you had dax ch 1 selected or i would have mentioned the menu. Glad its working now.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
