TX Delay needed for FT8 and PGXL?
Greg - KØGDI
Is there a TX delay needed for FT8 while using the PGXL amp?
20 ms should work perfectly.
Mack
W4AX
Alpha Team0 -
I wasn't sure. Thanks Mack!
Interesting topic. Not sure if Mack was referring to the settings in SDR or what FT8 software you're using, but if it is wsjt-x, there is a setting under file, settings, advance, to cause a delay between PTT and the start of the transmitted audio. I think the default for wsjt-x is .2 seconds so that delay might already be in effect.
I was referring to SmartSDR TX Delay. Mack W4AX0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
