Newbie question , Looks like I QRM second slice ?
Ed N5DG
I have slice A on 50,098 CW and slice B on 50.313 FT8 . When I tune or use the paddle on Slice A , I see spikes or interference on slice B . I wanted to ask before using the amp.
Tnx Ed
Tnx Ed
Ed
Probably normal operation.
Slice B RX is seeing Slice A transmitting.
What frequency was the received frequency at?
#FlexRadio IRC chatFor real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
Hello Jay , I was transceive on 50.098 sending CQ's , looking at slice B while transmitting CW on A , I see spikes as if I'm overloading the Slice B receiver that in on 50.313 ! This is with 50 watts , would I damage the receiver by using a KW ?
Ed0 -
Sending a screenshot ,, most likely nothing to worry about
Ed1 -
Ed
The Slice B RX slice should be disconnected from the antenna input when it's connected to Slice A as it transmits. I do this quite regularly.
If your using 2 antennas on 2 slices, maybe. There is a worksheet at ...
http://www.flexradio.com/downloads/flex-6000-fdx-power-calculation-worksheet-pdf/
That should be used to figure that out, if that's the case.For real-time discussions
What radio are you using ? If its 6300/6400/6500 then there should be no problems. If its a 6600/6700 and you have each slice connecter to a separate antenna, then you need to be aware of the coupling between the antennas.. The 6600/6700 should try to self protest but …
AL, K0VM
Hi Al , I'm using a flex 6600 , I have one antenna connected to antenna port 1 only , I have 3 slices open , all on 50 Mhz ... A= 50.098 CW , B= 50.313 wsjt and C= 50.323 .... When I transmit in slice A CW, I see QRM in the other two 50 Mhz slices ... Look at the waterfall above . I only used slice A and B in the photo . Since I'm new to Flex Radio , I need to know if I can damage the radio with this setup? I only used 60 watts for testing . I would hate to use a KW and damage the receiver . I would think I'm okay with this setup but it look nasty with only 60 watts
Tnx Ed0 -
Ed, you described a 6600 using 3 slices on 1 antenna.
When that antenna is moved to Slice 1 TX power amplifier, slices 2 and 3 have their antenna removed and are picking up internal signals. On that rig with 2 SCUs, as a test, put slice 2 and 3 on a transverter port with a very short wire stub or dummy load. That will display real signals.
Your setup is the safest for front end protection BUT don't expect normal RX when any of them are transmitting.0 -
Stan thanks , I'm not looking to receive on the other 2 slices B or C while transmitting on A .. I'm simply not wanting to damage the front end . Thanks for letting me know I have the safest setup for front end protection . I will now use my Amplifier if needed.
Ed0 -
If you only have one antenna connected, you are likely only using one SCU and it is isolating the other two slices when you Transmit. If you were overloading the other slices, then the auto overload protection would be kicking in and you would be getting a notification of the overload protection.0
Ken thanks , That's good to know . SDR is smart
Ed0 -
I guess that's why Flex named the software Smart SDR0
ED,
See section 32.4 of the flex users guide for' SCU overload fundamentals'
AL, K0VM
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
