Preset band buttons in smartSDR Windows
Craig Williams
A few weeks ago my "Band" button stopped working in the 80 preset position. When I selected the 80 Meter band it just stayed on the band I started from. I can get to 80 by entering a frequency on the keyboard but when I change to another band and then go back to 80 it won't change to 80. Updated to V 2.3.9, same problem. anyone else had this problem? I have a 6400.
Have you done a Hard Factory reset and try the BAND Button BEFORE you reload your Profiles.
Sounds like there is something corrupted in your default profile.
I think we would have heard from a lot of people if this was a software or hardware bug.
One thing with flex radios that people need to remember, if there is a problem that no one else seems to be having do a hard reset.
This is why it is VERY important to save a known GOOD Profile after every major change you do.
hope this helps
Bret
WX7Y
Did a cold reset after the 2.3.9 update. Brought up the program and it had my profiles already. Your idea is a good one I will try to load the Flex default profile and see what happens.0
Reloaded my profile from 6/10, problem fixed. Thanks0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
