Flex 6300 and Acom 1010 Connection
David McDonald
I have a Flex 6300 and an Acom 1010 amplifier. What RCA connection do I use ACC, TX1...?
TX1 is the keying relay for an amp on the 6300, it can be enabled and disabled in the settings so make sure its on there.0
Ok thanks a lot sir.
I have a 1010 and I use TX1.0
I use TX1 to key my Tokyo Hy-Power linear. Works great. You can check the transmit settings to ensure that TX1 is enabled. My 6400M was shipped with TX1-3 all enabled.0
Ok great just got the 6300 and coming from the Icom 7300 there's a learning curve.0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
