tx audio in powered speakers
Chris Knight
Just got my new 6400 and got it hooked up on the air. Worked 7 of the 13 colonies in about 30 minutes...its like shooting fish in a barrel with the Flex!!! I'm using a pair of Bose Companion 2 powered speakers. I am hearing my TX audio in the powered speakers when transmitting...I never had this problem with my Flex 3000 or 6300 and these same speakers. I've added ferrite cores to both ends of the speaker cables with no change in it... Any thoughts or suggestions?
Thanks & 73,
Chris W4CDK
Thanks & 73,
Chris W4CDK
Ferrites on the power cables, and if you are still getting tx audio, you might want to open the speakers or amplifier section up and pop in some bypass caps in the power feed.0
Double check and make sure that the MON (monitor function is disabled) should be grey
enjoy the new rig had mine just over a month , coming from a Flex 3000 and really enjoying the new rig.0 -
Whats really odd is I never had this problem on my 3000 or 6300 with the same speakers. I'll try ferrite on power cable of speakers. I did put the 6400 in a different location than the other two radios were so maybe in a proximity thing.
Where is the MON feature on the Maestro? I didn't state that earlier, but I'm not using PC for control, using the Maestro...its new to me also never had one on the 63000 -
You have changed your shack arrangement and placements. It sounds much like a proximity issue.0
If you have the Bose Companion speakers hooked up to both the rig and computer, you likely have a ground loop problem. This can be solved with a simple ground loop isolator available at Amazon, or from many automotive audio shops. Since it is at low levels, you can use an inexpensive one that is about $10 US. You should only need it on either the rig or computer. Not both. I have mine on the rig side. It might solve the problem even if you only have the rig connected to the speakers. Ken - NM9P0
Press mic gain knob to display Mon, Proc, level, etc0
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
