no signals, no output on Flex 6500
mdjdmi
Mates:
Everything was working as it should on my F6500 running SSDR 2.3.7 until this afternoon. I started up SSDR and it seemed to start normally. However, I have no signals on receive and no output when I click tune - just maximum SWR reading with no output. It is acting like the antenna is disconnected but I know the antenna is connected to ANT 1. The dropdowns say ANT 1 is the selected antenna, LOOP A. Does anyone have any inkling as to what may be the problem? Is there a fuse in the antenna circuit that may be blown? When I switch the antenna to another radio (IC-7100) that radio functions normally as it should.
Thanks....Arnie W8DU
Arnie, had the same issue yesterday, and found it to be 1 port of my external antenna switch was bad. When antenna switch was bypassed, all was back to normal.0
And try connecting antenna to ant2 and check it.0
Did all of that and connected antenna directly to ANT1 and ANT 2 alternatively - no dice. It is acting like there is no antenna attached. It's something in the radio - not the antenna system or coax since the same coax connected my to IC-7100 makes it jump off the table with signals.
Any other ideas, anyone?
Tnx de Arnie W8DU0 -
All I can suggest at this time is a full power-down & reset (holding the power button on the box for 2 secs) of the 6500, then restart SSDR and see what happens. That should put everything back to default level. If it still isn't working, it might be time for a Help Desk ticket, and getting Flex support involved to help with troubleshooting/diagnosis.
Don
And yes, if I remember correctly there are 'sacrificial' diodes in the antenna line to protect the components in case of excessive RF incoming. It may be that it has blown. But again, best to have Flex help you determine if that is the case.0 -
Oh my, do I feel foolish! Turns out that I was selecting the wrong radio on my coax 8 way coax switch. Duh!!!! All is well now! Thanks to all who responded to this lapse in memory. I suppose I am entitled to do that every now and then at my age. I will try not to make it a habit, though.
Have a great July 4 one and all.
73 de Arnie W8DU0 -
Oh my! I think we have done something like that before, at least once. (At least I have). ... a small mistake so simple that it blocks the ability to even consider it while we examine a multitude of much more complex possibilities. They often occur shortly after making a configuration change in the station layout and the brain hasn’t caught up to the new system. Glad you sorted it out. Good luck. Don’t feel foolish. You’ll laugh about it soon enough, just as we have ! Ken - NM9P0
Thanks Ken and Paul for your words of consolation. I just have to chuckle and how we often are the source of our own foibles.
73 de Arnie W8DU0 -
done it here (more than once)....
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
