FT8 Transmitted Signal in Panadapter
Neil D Friedman N3DF
Member ✭✭✭✭
I have a 6600M and am new to FT8. What should my transmitted signal (35 watts) look like in the slice panadapter? Bandwidth is set to 5 kHz. Thank you.
This is what mine looks like with 35 watts.
Your spectrum is probably fine. The one above is. Notice the symmetry of it which is indicative of a properly generated signal.
You have to ignore the signals assumed to be spurious emissions. When we show the transmitted spectrum, we use the receiver in the radio to show the actual transmitted RF coming from the DAC and that will have harmonic components of the primary signal. Also, some of these "signals" are harmonics from the DSP in WSJT-X when it generates the FT8 (or whatever mode you are running) tones. What is actually transmitted as RF are only the signals inside the TX filter. And also pay attention to the magnitude of the signals too, most of them are -125 dB down and almost 90 dBc, more than twice the FCC requirement for spurious emissions (but that is moot since they are not being transmitted as RF).2
- 382 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 933 Genius Products
- 341 Tuner Genius XL
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
