Slice Master issue
Bill English
Well I got VE7CC working with Slice Master, but I notice a little quirk with it. Today when listening to FT8 I noticed a tiny breaks in the audio. I could not see them on the panadapter, but I sure could hear them. Listening more carefully I noticed these breaks in the audio were exactly every ten seconds. I started closing stuff and it stopped when I closed Slice Master. I have found the following, It does not do it when Slice Master is first opened. It has to run a while. But once it starts, it is there to stay until SM is closed.
Has anyone else noticed this? I am running a 6300.
Bill K4FX
Bill K4FX
Hi Bill,
This is second time this has been mentioned. Your clue about every 10 seconds was very helpful. Slice Master looks for changes to its spot database every 10 seconds and sends the changes to the radio. I didnt hear it at first but after turning up the volume a bit, it's there. I changed the update rate to every five seconds and the audio breaks followed.
I think we might have to get Flex involved on this one. Other than not sending update, I cant think of much else to do.
--Don
I noticed it as well along with a "stuttering" when switching between profiles so I turned it off.But I do not have SM properly set up. Under the launch tab I show no programs. I did have CW skimmer under the launch tab until I deleted it, but first I had to install skimmer in the directory dictated by the author. It would not pick it up otherwise. I'll play with it some more to see if I can get wsjt showing but so far no luck.
Don, I have been using the older version .4c and I don't get the audio breaks and the spots are working. I have the same problem with .5 and it don't get the issue the first 3 or 4 minutes slice master is open but then I get the audio drops every 10 seconds.0
I have the audio drop every 10 seconds as well and I'm running .5 of SM. Close SM and the audio drops stop.0
Hi Burch,
I still dont understand why the problem doesnt show in .4c but it's there in .5 for sure.
I've added a slight delay between spot updates to the radio and that seems to have fixed it.
It will take me a bit to come up with a proper work-around but I'll get a bug fix release out as soon as I do.
--Don
Now that you mention it Burch, I did not notice it on version 4c0
Slice Master v0.10.5a has a work-around for this issue. It's now available at https://github.com/k1dbo/slice-master-6000/releases
3 -
Awesome, thank you!!
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 918 Genius Products
- 295 Shack Infrastructure
- 207 Networking
