Slice Master V's SDR-Bridge CW Skimmer
Trevor-EI2GLB
HI All
I have just installed Slice Master to see if it will improve the latency issues I am seeing in CW skimmer using SDR-Bridge, For some reason CW skimmer looks different using Slice master and I can't seem to find a way to make it look like it does when using SDR-Bridge, anyone any ideas how I can alter this, looking in the settings it all seems the same,
Left is skimmer using Slice master Right is SDR-Bridge, Right is the views I prefer,
Trevor
EI2GLB
Trevor
EI2GLB
My Skimmer with SDR Bridge looks like the image on the left.0
Check your skimmer config file location. You’re seeing default on left and customized on right. Path to config file had changed.0
Trevor,
In CW Skimmer there is an option under the View Menu called "Waterfall settings". Select the 'Color' option.
--Don
Thanks Don I stumbled across it just after asking here, Thanks also for the time and effort in developing Slice Master I look forward to trying it out
Trevor
EI2GLB0
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
