New Flex 6000 and IPad Question?
David McDonald
I have a Flex 6000 series coming and wanted to know if the Ipad Pro would be good for it? Also, Does the flex system itself need to be connected to my desktop and then connect my ipad pro or can the flex system be directly connected to the router bypassing my desktop?Thanks,73
The iPad Pro is a great tablet. I connect my Flex 6400M directly to the router hub not to the PC. This worked very well for me. The iPad app for Flex by Marcus works FB with the iPad Pro.0
Ok thanks for the response ,so I can setup the initial settings from the ipad after installing the sdr app from the IOS store?0
That should do it.0
I have 6600 for a week and still in a process of learning it. I was very interested in iPad experience, however installed SSDR on iPAD pro 128gb last week and experiencing intermittent unresponsive buttons. I have to close App and reopen several times to make certain button working. This morning I could not unmute speaker, many clicks did not do anything, I still could move across the band and switch bands, but unmuted speakers only after closing/ opening App twice. I am not sure it worth the price yet, unless someone could tell me there is some configuration I have to change. Sergey, KN7K0
Might be an adjustment or software issue because I have watched several you tube videos of guys using them with Ipads without problems. Thanks for the information.0
Could be and I am trying to find out if there is any optimization settings for iPad.
Sergey, KN7K0 -
I have used SSDR/iOS from 29 countries now over 3G, 4G and WIFI.. works fabulously both on my iPad Pro and my iPhone X. It's even worked over the **** connections on Airplanes and Hotels. Definitely works well from my cars in SOCAL and in France over 4G
It's probably your network connection rather than SSDR/iOS. How fast is your home network - upload, download speeds, LAN Speed etc?
Suggest you try lowering display/waterfall refresh rates under the displays tabs and perhaps use the low speed network setting in SSDR/iOS
I changed from 2.4G to 5G my home WIFI network - same thing
You can see here, working after closing and reopen again.
https://drive.google.com/open?id=1V-wavY9I1eAE8TQMKqH84fNElOkCGEuM
Sergey, KN7K0 -
I followed up instructions for "common issues" and reduced FPS and Rate, also changed Net to Slow. While panadapter barely moves, all icons respond fine. This is just on about 2h of testing. So far looks ok. I did not test any TX functions yet, only RX.
Sergey, KN7K0 -
David,
Sorry to hijack your thread, but I decided to ask following question here since it is related and maybe you would like to know answer as well. Hope other users could answer.
I purchased SSDR for iPAD and hoped I would be able to use it on iPhone as well, just to check propagation and maybe listen. I do not see any other option besided to purchase it again.
Question: Is putchase limited for 1 device only? Is there any way to use it on iphone since I already paid for iPAD?
Sergey, KN7K0 -
As long as the iPhone and iPad are on the same iTunes account you should only need to purchase it once.0
Cool, I had only choose to buy it again on iPhone. I click cancel, and than another screen popped up saying that I already purchased it and if I would like to get it for free. I said Yes and now it working on iPhone as well. Thank you1
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 942 Maestro
