Transmitter RF getting into ethernet
2»
  • Lionel
    Lionel Member ✭✭✭
    edited June 2018
    Inadvertently while rushing around, yes, and the RF into the shack lit the place up.  It was unpleasant.  That bump from a balanced feedline to coax seems like a big deal.  I have seen some say that you don't really need the choke but I think unlikely to work well.
    By the way I am using a current choke 1:1.  I've never tried 4:1 but suspect the result would be a low impedance at the tuner, on some bands, that would be out of range.
    $50 isn't a bad price from that company.
    Good luck with your installation.
  • Good discussion RF interference and grounding issues can get tricky when you mix coax, ethernet, and multiple cables in a rig like this. If you’re replacing or re-terminating coax feedlines, I find using a proper coax crimper (not cheap pliers or makeshift tools) makes a big difference. A reliable crimper helps ensure solid connector crimps, shielding integrity, and minimizes unintended RF leaks which might help avoid some of the weird RF/grounding issues you’re seeing.
    https://jonard.com/catv-coax-vdv/compression-crimping-tools
