Mox button Dont work
Jay Spaulding
Smart SDR V2.0.
I tried to use the MOX button a couple of times while not in remote cause I'm sitting at my desk right next to the Flex and I just clicked on the MOX button and talked into the mic and well nothing happen. It keyed but no Audio. So I hit the foot switch and everything worked fine. So I was wondering if anybody had that problem also. Or has anybody even tried it. Cause most of the time I wouldnt even bother with it. Not sure if its going to work in a remote setting or not.
Jay
W0JAY
Jay
W0JAY
Dax isn't on is it, if it is it will act exactly as you describe.0
I just tried it here on 20m SSB and it works. Clicked on MOX, spoke into the mic, got power out. This is with 2.0.17 on a Flex 6300.
Doug K4DSP
Sounds like DAX is enabled for transmit.0
For some strange reason my MOX doesn't work when using 2m FM. It will key the transmitter but I get no audio out of the mic. I've tried everything but still no go. This was also a problem on the previous 2 versions of SmartSDR. It is not isolated to v2.x. No DAX enabled.
Norm - W7CK0 -
Thats what it was.. I was running digital wsjt and never turned it off. But I can hit the foot switch and it work No problem.
Thanks guys.
730 -
If you save separate Mic Profiles for FM, SSB, DigiU, etc, then you won't need to remember to turn Dax on and off whenever you change bands. The rig allows you to link a profile with a mode. It remembers the last profile you used with that mode.0
Norm,
I just tested here with my 6300 and 2M transverter. No problems transmitting mic audio when keyed via MOX or PTT on FM.
Doug K4DSP
DAX is turned off
I am using 5000A mox will not work when VAC 1 & VAC 2 are turned on and I am working remotely. Dax is turned off0
I have the 5000A, Mox will work but if I turn on VAC 1 & VAC 2 when I am working remote when I use the Mox button to transmit it will not transmit when Vox 1 is turned on
- 632 The Flea Market
- 126 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
