Filter Skirt Issue 2.3.7.10 with WSJT-X
edited January 2020 in SmartSDR for Windows
Running a 6400 with the new 2.3.7.10 software. In WSJT-X I am seeing distortion at the end of my filter skirts in the WSJT waterfall. I do NOT see the same thing in the Flex waterfall. I did not see this issue in WSJT with previous SmartSDR version?  My DAX settings are the same as the previous version of SmartSDR. Is anyone else seeing this behavior? It is hindering reception on the filter ends. Filter is set to auto or third position in digital mode. See screenshots below taken at 50.312 then 50.313 a few minutes later. It is not band conditions.
 TIA! Dan KG0AQ 73
Welcome!
  • Member ✭✭
    edited June 2018
    I believe this is a function of the WSJT-X Wide Graph. If you set your filter for 5K the light blue on the laft and the yellow on the right will go away and your background will be uniform.
    Paul W5PF
  • Member ✭✭
    edited July 2019
    I see this occasionally with my 6700. My fix is to reload the profile and all is well again. Happened with the older version as well.
  • Member ✭✭
    edited December 2019
    Yes, I can get rid of the right side trash/hash by widening the filter. But the little hash on the left is the real problem. Especially with KH1/KH7Z transmitting at 303hz. Any ideas on widing the left side? Can't seem to get past zero with DIGU.  Thanks for tip!
  • Member ✭✭
    edited July 2019
    Excluding 60m, go lower in frequency with the VFO.
  • Member ✭✭
    edited July 2019
    Oh, BTW the waterfall on WSJT-X has no bearing on decoding signals.
  • Member ✭✭✭
    DO you see it if you turn off the wide graph 'flatten' function.. ?
    AL, K0VM
  • Member ✭✭
    edited June 2018
    Dan,
    That little bit of hash goes away for me when I use the 5K filter. I don't think there is really any signal there that would interfere with the KH1 below 500 hz. You might pose the question on the wsjtgroup reflector on yahoo groups. Lot's of help there.
    Paul
  • Member ✭✭
    edited January 2020
    My experience has been that with the hash at either end of the visible spread, has been on the laptop but not the main desktop, so perhaps something in the machine is generating or letting in the hash.
  • Member ✭✭
    edited June 2018
    i have it on the flatten function in the pictures. If AI4FR's comment is true then its all a moot point I guess. Still would like to see a clean waterfall. hi hi
  • Administrator, FlexRadio Employee admin
    edited June 2018
    Turn Flatten off.  The FLEX-6000 does not need DSP compensation for the filter characteristics because the DSP filters are already flat.
    edited June 2018
    Go into the filter setup (Settings->Radio Setup->Filters) and set your DIGx filters for lowest latency, not auto.
    AAnds make sure the slice RX filter is equal to or wider than the WSJT-X waterfall (check the filter skirt settings, not just the size)
  • Member ✭✭
    edited June 2018
    When I uncheck flatten all  get is a solid red waterfall with no signals?
  • Member ✭✭
    edited June 2018
    Turn down the RX audio in DAX. BTW, that level meter on the left hand side of WSJT-x doesn't do much for decodes either. There is no perfect spot such as a level of 25 is better than a level of 30. Keep it in the green. If you have concerns about the waterfall and reception/decodes, turn the waterfall off and watch what happens. I'd bet WSJT-x still decodes just fine with no waterfall. Good luck with it.
    edited June 2018
    Adjust your audio levels.
  • Member ✭✭
    edited June 2018
    Dan
    If you need help with WSJT-X adjustments, I'm fairly experienced with it, and would be available in the #FlexRadio IRC chat channel. It might be quicker, if we discuss it in realtime. Anyone else interested is welcome too.
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Member ✭✭
    edited June 2018
    It absolutely does. The bins/pixel setting controls the range of frequencies you will decode. You won't decode any signals higher than the highest frequency you can see in the waterfall. Don't believe it? Set bins/pixel to 1 and try it.
  • Member ✭✭✭
    edited June 2018
    With Flatten off, you will need to adjust the gain/zero sliders to the right of the flatten button in wide graph..  The down side is that when the ssdr noise floor/agc-t etc. change, the sliders will need to be adjusted again.. .. But it will show the 'real' levels in the wide graph, not what flatten chooses to make them..  I normally prefer to use flattens despite the fringes that flatten creates..
    AL, K0VM
  • Member ✭✭
    edited June 2018
    I had DAX receive at 32. Now with flatten off I'm at 13. Very touchy without flatten though. I get a black & blue background at 13 and at 14 I get a blue background with  hash. Sigs on WSJT meter are around 25 to 30. I might give you a call later IRC Jay. Thanks,
    See new screenshot without flatten and DAX at 13
  • Member ✭✭
    edited June 2018
    Doug
    Interesting
    Agreed, signals not seen in the wide graph don't decode.
    Somewhere I got the impression that the 40m FT8 portion began at 7.074 MHz and extended 2K above that. A setting of bins/pixel to 1,  Start 0Hz, limits the widegraph to a maximum of 1.45K, I can't widen the widegraph any wider than that. So bins/pixel 1, excludes decoding signals from 1.45K and above.
    In order to decode the entire 2K FT8 portion bin/pixel 1, Start 0 Hz, just won't work for me.
    Setting bin/pixel 2, Start 0 Hz, with the widegraph widened out to it's maximum gives me signals from 7.074 MHz to 7.077 MHz which is plenty wide, but the widegraph window is wider than I would normally use it.  But since I often see FT8 being worked above the FT8 portion in the JT-65 portion I wont be missing those outliers.
    My point here is that I had been reducing the widegraph width to only display about 2K total, so I was missing any outliers above 7.076 MHz, I didn't know that the widegraph displays width, excluded decodes.
    Now I do.
    Now I think …
    Bin/pixel 4 Start 0 Hz, for me, is about optimum, for decoding FT8.
    I use JTAlertX, and it's window size isn't adjustable in width, I then adjust both the WSJT-X, and widegraph windows to it's width which takes up approximately half the width of my desktop display. which gives me a widegraph display from 7.074 MHz to 7.0768 MHz, which combined with a 0 Hz to 3000 Hz DIGU filter width, will allow me to decode some of the outliers, and also move the filter edge hash out of the widegraph window.
    This is an improvement.image
    Thanks!
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Member ✭✭
    Thanks to all that chimed in with suggestions. I have now changed a few settings and all is good.
    Check out the cleaner waterfall and traffic on 6.
    1. Widened filter to 5K
    2. Cut my DAX gain down from 32 to 18
    3. I went back to flatten because without it the gain requires periodic adjustment
    73 Dan KG0AQ and hope to catch you on FT8 sometime. This is truly a knowledge base!
    OBTW  I received my return shipping label for the PEN and Preamp RMDR enhancement
    Thanks Flex,
  • Member ✭✭
    edited July 2019
    Glad you got it going. I use flatten as well, with 3khz filter but cut in from 0 100hz as there is never any signals down there. So in short, it is a 2.9Khz filter. Instructions state to start at 200hz which is probably better than my 100hz starting point.
    W5PF's advice above is excellent. The WSJT reflector has covered the waterfall issue several times in the past discussing what it does and even having the designers chime in with clarification. As Paul stated, lots of good info there.
