slice-master not working
Don w2xb
updated software this afternoon. Now slice-master is not bring up cw skimmer or spots. Went over every thing dozen time, must be missing something. I slice- master set for" telnet://ve7cc.net/". It doesn't show any spots. Worked fb before upgrading with cw skimmer . Any hints? ( Using a 6600/m)
Don...w2xb
Don...w2xb
Don,
I'm confused about the changes you made between when it was working and now.
If it's just that CW Skimmer is not starting, take a look at the Slice Master status area. Just click there then let the mouse hover. You should a pop-up with the last few status messages. If you have anything wrong, like DAX not being enabled for example, there will be a message in the pop up telling you what needs to be fixed.
--Don
Don, what does it mean when it say warning, time is not in talerence?0
Bill,
When Slice Master starts up it compares your system's time to a time source on the internet. If the two differ by more than a second the warning is generated. The warning was added to help out the folks who have trouble with WSJT-X decodes. My guess is that if you tried WSJT-X, you'd have some trouble.
--Don
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
