i have many virtual ports under Other devices FabulaTech_virtualPort
jim
flex 6500 windows 7 i7 machine SmartSDR 2.2.8
many FABULATECH_VirtualPorts under Device manager , other devices most are ports i had set for my comports in SdmartSDR
the only port under PORTS(com & lpt) flexcontrol and my printer
now when I load smartSDR I get error message that DAX driver may not properly installed
any ideas would be great
thanks
jim
wb5aaa AT cox.net
thanks
jim
wb5aaa AT cox.net
Jim the 2 are not related. The Fabulatech ports will disappear when you start SmartCAT. The DAX port error is likely related to the 1803 update from Microsoft. You can read this to fix
https://community.flexradio.com/flexradio/topics/most-common-fix-for-dax-driver-errors-in-windows-sp...
You have both DAX and CAT messed up in your system. Both look like driver errors. CAT looks like the ports were removed via Device Manager and the registry is messed up. I recommend you open a HelpDesk ticket to get this cleaned up. It could be messy.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
