New to V2 - Cursor Delay When Using Tune Guides
Paul - K6HR
v2.2.8.109
When I activate the Tune Guides the 'guide' moves much slower than my mouse cursor. Is this by design? Perhaps a hardware setting that could be adjusted to eliminate the lag?
Mine keeps up ok, But my cursor loses the line sometimes and they separate.0
The acceleration is slowed down a little bit because if it moved faster it would be harder to land exactly on a narrow spot on the spectrum display.
When you said 'slowed down a little bit' (and mine is massively slow) I knew there had to be more to it. I fiddled a bit more and found when I use a lower screen resolution the lag time vastly improves. My big monitor is set to 3840x2160. Thanks for the roll!1
- 256 Community Topics
- 491 The Flea Market
- 7.4K Software
- 137 SmartSDR for Maestro and M models
- 333 SmartSDR for Mac
- 241 SmartSDR for iOS
- 225 SmartSDR CAT
- 162 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 791 Maestro
- 42 FlexControl
- 837 FLEX Series (Legacy) Radios
- 738 Genius Products
- 394 Power Genius XL Amplifier
- 257 Tuner Genius XL
- 87 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 589 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 816 Third-Party Software
