New to V2 - Cursor Delay When Using Tune Guides
Paul - K6HR
v2.2.8.109
When I activate the Tune Guides the 'guide' moves much slower than my mouse cursor. Is this by design? Perhaps a hardware setting that could be adjusted to eliminate the lag?
Mine keeps up ok, But my cursor loses the line sometimes and they separate.0
The acceleration is slowed down a little bit because if it moved faster it would be harder to land exactly on a narrow spot on the spectrum display.
When you said 'slowed down a little bit' (and mine is massively slow) I knew there had to be more to it. I fiddled a bit more and found when I use a lower screen resolution the lag time vastly improves. My big monitor is set to 3840x2160. Thanks for the roll!1
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
