Setting up PGXL
Bernie W7DMC
Bernie W7DMC Member ✭✭
edited June 2020 in Power Genius XL Amplifier
In the setup instructions for the PGXL it indicates that a Tx Delay of 20 ms or more must be set (and enabled). In working on this step it appears I have to set the Tx Delay for every Profile I have created one by one. Is that correct ??
  • NX6D Dave
    NX6D Dave Member ✭✭
    edited December 2019
    For each TX Profile.  It is a TX Profile parameter.  It does not appear to be dependent on the band.
    I do wish we had a Profile Editor so we could make changes like this quickly, instead of via the radio GUI.
  • Varistor
    Varistor Member ✭✭
    edited June 2020
    Is 20 ms for SO2R mode or always? 20 ms is a very loooong delay. The typical modern amp needs about 5-6 ms if using vacuum relays and less if pin diodes.
  • David Decoons, wo2x
    edited June 2018
    20 ms is the minimum for the PG XL for all operating styles, not just so2r
  • Varistor
    Varistor Member ✭✭
    edited June 2018
    Thanks. This begs the question why. Such long delays are usually associated with the slow, open frame relays from the past. Today’s relays are in the 5-10 ms range and can be further “accelerated” by some simple “tricks” as implemented by Acom, Alpin, etc.
    edited June 2018
    I don’t know that answer. Dave
