Flex 6500 NO RF out
Ok I have a flex 6500 SmartSDR Ver 2x I just purchased a month ago. It has been working perfect with a heil Pro set headphones until last night when I turned it on and found it had no RF out (transmit light does light). When I key the radio the waterfall registers that it is transmitting and my Amp Buffer lights up. I can hit monitor and hear myself. But no RF. I tried to tune and slowly increase power nothing.
I have read just about everything I can find in the community forum with no help.
Things I have tried so far:
A different mic.
Checked slice for correct antenna
Checked Dax
Checked Power slider
Turned bias on/off
Changed profiles
rebooted PC numerous times
Hard Reset 6500
Downgraded to SmartSDR Ver.1x
Upgraded back to SmartSDR Ver.2x
Running Windows 10, 64-bit Enterprise.
ESD Diodes were just replaced prior to my purchase by Flex. (not sure if this helps).
Any other suggestions? I think I might be glad I transferred the warranty if I have to send it in.Comments
Pat Have you tried pressing the Tune button and moving the tune power slider all the way to the right (max)? It really sounds like you need to contact us and open a trouble ticket!
If you did the 1803 windows 10 update. Go to PRIVACY, MICROPHONE, and turn it back on.0
If you are on ssb, try other modes such as CW or AM. Is there output on tune? 73, Jim0
Some things that come to mind; Use the default profile Check Supply voltage at the radio, load flexmeter if you can to monitor voltage, maybe it drops under load and radio will not generate an rf output. Try to transmit on cw mode. I’ve never messed with the tranverter output but I’d make sure the radio isn’t set to transmit low power out of the tranverter jack. Not sure I know enough about this aspect. Do you have another receiver to see if any RF is going out Just run ssdr , no frstack, ddutil, etc. I’m sure someone with a lot more flex knowledge than me will jump in, but that’s some stuff I’d look at. What I have found with my flex is it is usually pretty simple when I find it, but baffling while looking.0
There is a TX Inhibit selection in the Radio Setup under Settings , top right of SSDR screen. Check that before sending away.
Thanks Neal attempted that no luck. I will open a ticket.0
Kent I didn't think of this but I checked and it's on. Thanks but no dice.0
Thanks I tried it prior to post.No luck0
I do have other rigs but not at this qth. I will need to bring one over. thanks0
There is a transmit high / low filter setting that can cause this behavior. Please check it and set for low=100 and high =3000
_..--
k3Tim0 -
Thanks I will check when I get home and reply0
I checked the filters and they are set as you mentioned at 100 and 3000. No Luck.0
I've had this happen to me. Thought I was transmitting on antenna 1 when somehow antenna 2 was selected due to an old transmit profile I had used in the past.0
No I checked that I opened a case with flex
This is a hardware issue being handled via the HelpDesk.0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 874 Genius Products
- 313 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 136 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
