HDMI cable for 4K monitor
Michael Wheatley
I am running 3 monitors on my PC, one of which is a Samsung 40" 4K TV. When I transmit with my Flex 6400 on 40M (anything above 5W) the Samsung screen goes black for the duration of the transmission, This does not occur on other frequencies, nor does it occur on my other 2 monitors.
Obviously I have an RFI problem on my HDMI cable connection to the Samsung monitor. I can kinda fix this by putting lots (8+) ferrite beads on the HDMI cable. The cable I am using is a run-of-the-mill 6' HDMI 2.0 cable from Amazon.
I'm looking for suggestions for
1. a better HDMI cable with better shielding.(if possible a source and manufacturer/model #)
2. something better than 8+ ferrite beads
Michael Wheatley
KM6LHD
Michael Wheatley
KM6LHD
I think its more the monitor I had the issue with my LG monitor then switched to the TCL 4k 43" and no rf issues the monitor works great keeps on working when I transmit. It used to happen only when I used my KPA500 now with the TCL 4k as a monitor when I use 500-600 watts it has no effect on the TCL.0
I find more often that the rf gets into the power cable, put the correct mix beads on that also.1
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
