6400M ATU Installation
Rod KI7CQ
Just received the ATU for my 6400M. I took the top cover off but can't figure out where it goes.
Are there installation instructions for this ATU? There aren't any in the Downloads section.
Thanks.
Rod
Thanks.
Rod
I have taken my flex-6400 apart and have some pictures for you.
1: Used #8 Torx to remove all screws for bottom, including the feet.
2: On the right, looking from the front, there is a metal plate
just above the PA.
3 : Remove the 4 screws, one is the back.
4:The 2 open male connectors near the back of the PA , plug the
longest coax with the straight connector to the left side and
short one to the right side connector. Feed through the hole
first, do not grab the coax or pull on it. it takes little pressure
to insert the connector.
metal chassis.
5: Plug the ribbon cable into the Pa board first, on the right side of the picture.
6: **** down the ATU metal frame to the unit and then
attach the ATU with 4 screws.
7 Plug the coax and ribbon cables.
I hope this helps and my direction are not confusing, good luck.
Mike, VA3MD
Thank you very much for the help, Mike. I will do this tonight.
Rod
For everyone else who needs to do this, Mike's directions worked great.
Thanks again.
Rod
I cant believe it didnt come with detailed instructions0
- 112 SmartSDR+
- 944 Maestro
