IQ DAX channel 2 is busy all the time, even after a reboot. How to find out what is causing it?
Andy - KU7T
I use Slice-Master and CW skimmer. IQ channel 1 works fine, but for some reason my IQ DAX channel 2 keeps in busy state, even after rebooting. How can I find out what it is?
Thanks and 73
Andy
KU7T
Thanks and 73
Andy
KU7T
You have it open already from not exiting properly...you need to close it before you can open it again....
Go to your USERS file and open your file..... then APPDATA then LOCAL then TEMP
With SM off there should be no slices showing so delete any that are and reboot SM and you will be ok You will probably see a WSJT-X Slice 1 or 2 or an AB depending on what you called them but with SM closed there should not be any so delete any that show ... always close SM first and let it close the slice windiws0 -
What file do I need to edit. Under TEMP folder there is nothing that looks like DAX or SM related....
Andy
KU7T
Andy,
Is there any chance you have DAX Control Panel running on another computer? In the DAX Control Panel hover the mouse over the button for your IQ Stream 2. You should get a pop-up telling you the IP address of the other computer... if that's what's going on.
--Don
EDIT: ...sorry, it wont tell you the IP address of the other computer, but it will tell you that it's in use by another computer.0
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 941 Genius Products
- 345 Tuner Genius XL
