RF causing issues
You're probably correct, the stubs probably wouldn't work in this situation as stubs are usually used to lessen RFI from harmonics getting into other electronics. You're in such a strong radiation field when the antenna is pointed at you, that it's going to be almost impossible to shield your electronics, as you're found out. The only solution I can see is to just run <400W when pointed toward your station. You could turn your station into a SCIF by lining the walls/ceiling with RF radiation barrier, but that would be a lot of work, and probably impractical for your setup. https://tinyurl.com/yap4nser
Hi Jon,
I had RF problems a few years ago that sound similar. In addition to grounding and chokes I also added a short fiber link in the shack to eliminate RF from getting into the radio and PC from the LAN cables which are like antennas. It will also protect both the PC and flex from power and lightning surges. It easy to do and not too expensive ($100 - $150)
Here is a link to my fiber setup.
http://nn4zz.com/FLEX6700.htm#Ethernet_Lightning_Protection
And a link to my other RF mitigation steps:
http://www.nn4zz.com/FLEX6700.htm#RF_issues_and_solutions
Regards Al / NN4ZZ
4 -
Okay, after disconnecting everything from my computer and operating it remotely with teamviewer nothing changed. I still had the interference. After reading Al's note I went back and revisited the ethernet cable from the Flex to the switch. I had previously added one mix 31 ferrite to each end of the cable but I decided to try a new cable and a bigger ferrites that allowed me to get three turns. Problem solved!
I'm going to take Al's advice and add a fiber link between the radio and switch. I had been meaning to do that since my previous 6500 took what was believed to be fatal surge through the ethernet port that left the radio unrepairable.
Thanks to everyone who helped with their comments.
In my case it turned out to be the power supply for the Fiber optic to digitle converter. Useing my spare astron 35m did the trick. W8XO0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
