Initial Setup Questions 6400 w/ Maestro
Barry Young
I have read through the quick setup guides for the 6400 and the Maestro. My question is, do you install the SDR software on a computer first and setup the 6400 to run via computer and then setup the Maestro? Or do you connect the 6400 to an external display, but then, how do you navigate without mouse and keyboard? I see there are USB ports on the back of the 6400, do they support keyboard and mouse (also wireless keyboard and mouse?)?
Just want to get my ducks in a row, so the setup goes smoothly.
Any help would be appreciated.
Hi Barry, You're on the right path. Install SSDR on your PC first, DAX and CAT will be installed on the PC as well at this time. Attempt to connect to the radio and select the version of SSDR you just installed so that version gets installed on the radio. Click on that version # and let the radio firmware update. Then fire up the Maestro and have it update pretty much the same way.0
Thank you very much! Can’t wait to setup and start using this awesome technology!0
So if your radio is a 6400M then you connect it to the internet then the radio will check to see if there is a update available and then upgrade to it, then load that same version on your Computer.
If you have a SEPARATE Maestro then load the LATEST version on your computer and then upgrade the radio then bring up the Maestro and if it says there's a update just update to the version that you already installed on the computer.
Right now the latest release is 2.2.8
If these are different version's then every time you bring up the Maestro it will want to upgrade / downgrade and every time you bring up SmartSDR on the Computer it will want to upgrade / downgrade and you will needlessly jump back and forth between versions, so it is important to keep the versions the same.
Hope this helps and answers your questions.
Bret
WX7Y
Barry, I have a 6600 w/Maestro. I didn’t have a Windows PC at first. I just setup the 6600 w/cat 5 and connected the Maestro. It downloaded the new version and updated the 6600. I was off and running. I would add, because there is no dummy sheet. Write down all settings before you start playing. I spent a day with no output because of mic profile change. All the best! Steven0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
