6400 drifting issues only on 6M
N8SDR
While on 6 Meters I soon start drifting low within 2-3 minutes sometimes less even after doing a calibration this effect only happens on 6 m that we have seen so far, on 10-160 I do not encounter a drift issue, I have had several folks chase my TX signal while working on 6 meters, in both SSB and digital modes.(those are the only two modes i have tried on 6 M) but would assume it happens in all modes. Has anyone else experienced this, running software version 2.2.8.. Power supply voltage is stable, and a Non M model so no knob is being bumped, have even locked mouse scroll options, and why only on 6 meters.
N8SDR opened a HelpDesk ticket. This seems to be other stations drifting, not the radio. The TCXO is stable.0
Tim had me run a test to check the TCXO and it is working as it should. Using the station who reported me drifting, he swapped out radios on his end and we had a 20 minute qso on 6 meters in which there was no drift in frequency. Apparently his KX3 is having thermal drifts on 6 M also note this article in-which another user of a KX3 experienced the same KX3: thermal frequency drift- http://elecraft.365791.n2.nabble.com/KX3-thermal-frequency-drift-td7587010.html , this is not an issue with the 6400, sorry for the confusion.
Rick
N8SDR0 -
No apologies necessary. I'm glad you were able to get to the bottom of the issue.1
You will find many 6 meter stations off frequency as well.0
Not mine! 6700+GPSDO ;-)1
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
