SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
New version of Smart preinstalled on Maestro
IZ2ODM
Hello guys,
a simple question ; In case of buying of Maestro (that -of course- would have last release version software) , I have forced to pay anyway for 2.2 version to install on Flex or not?
73 IZ2ODM
Roberto
73 IZ2ODM
Roberto
Short answer: Yes.
Your Masestro should ship with latest software, I don't think you will need to pay for the software. That is for people moving from V1.**** an optional upgrade cost.0
Thank for both replies .It seems not so clear.....0
Do you have version 2 software on your Flex now? If so you will not have to pay. If not you will have to pay to upgrade the Flex radio to version 2.
.0 -
The radio has the software license. The Maestro does NOT check the s/w license.1
The licence is with the radio, if you have V2 your good to go0
At the moment I just have flex 6500 with 1.11.12 ; No Maestro. Should I buy version 2 or it will be vers.2 on maestro embedded?0
You will need to purchase the upgrade for your Flex radio. The new Maestro will not upgrade your Flex radio.
Bill said it, if you have V2 on your Flexradio 6xxx then Maestro upgrade is free of course. If you do not have V2 on your Flexradio 6xxx, the Maestro upgrade is still free but it won't work with your Flexradio 6xxx. Versions must match.
Your new Maestro will work with either version.
The radio and Maestro must be on the same version witch ever version that may be.
The firmware versions must match.0 -
The Maestro will work ? I guess that depends on your definition of work. If your connecting to your radio or remotely to someone else's radio, the Maestro version must match the radio you are connecting to.0
Yes, to get Version 2 features Version 2 must be on the radio.
- 18.5K All Categories
- 133 Community Topics
- 2K New Ideas
- 280 The Flea Market
- 6.2K Software
- 5.4K SmartSDR for Windows
- 93 SmartSDR for Maestro and M models
- 211 SmartSDR for Mac
- 188 SmartSDR for iOS
- 180 SmartSDR CAT
- 116 DAX
- 321 SmartSDR API
- 7.8K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 631 Maestro
- 29 FlexControl
- 777 FLEX Series (Legacy) Radios
- 411 Genius Products
- 243 Power Genius XL Amplifier
- 145 Tuner Genius XL
- 23 Antenna Genius
- 119 Shack Infrastructure
- 75 Networking
- 204 Remote Operation (SmartLink)
- 91 Contesting
- 308 Peripherals & Station Integration
- 87 Amateur Radio Interests
- 583 Third-Party Software
