A picture is worth a thousand words !
Juan TG9AJR
So here they are one down on the bottom board and the other half way already and no PEN sign yet !!!
I see you have re post ed again,
You can put them back on as I said in the other post. for now.0 -
To band-aid until the PEN arrives, you can stick the heatsinks back on and put a tie-wrap around each board and heat sink to hold it in place….. Mine heatsinks were still sticky..
AL, K0VM
Then one that felt is a bit sticky, the other one is at an angle but has more stick to it.
I seem to notice that the issue appears to affect 6600s more than 6400s...maybe just because there are more of them out there. I'm just curious. I run DDUtil which monitors the internal temperature. My very early 6400 (which was not affected) run at 28.6 degrees C in normal standby mode in DDUtil, while my 4yr-old 6500 runs about 1.3 deg C hotter. For those of you who have a 6600 and have DDUtil, what kind of internal temperature readings are you getting? It likely has nothing to do with the problem, but as I say, I'm just curious.0
Unfortunately did got to test and measure the temperature and now with one of the heat sinks down my 6600 is unplugged.
You can tie wrap the heat sink back on until you receive the replacements if you ordered them on the PEN. Others have done this successfully. The temperature measurement is not connected to the ADC heat sink temperature and is thus irrelevant. There is no reason to be concerned about thermal damage but you may get a high noise floor if it is not attached.1
Thanks Gerald, I will try the tie wrap or just wait for PEN. I tried to email the image to PEN but was return as spam.Could this be an issue with no pana/waterfall signal ?I have a ticket open for that matter but until yesterday I decide to open my 6600 to found this.0
My 6600 sits around 26.80
Yes, your issue can be related to the heat sink falling off.
I don't think that we can accept images on that email address.1 -
FYI, we use the same ADC on the 6300, 6500 and 6700 without heat sinks at all but on a larger PCB. Heat sinking is through the PCB so the new heat sink is much better at dissipating the heat from the ground plan. We did thermal camera tests before and after replacement and the ground plane side is much cooler than the original copper heat sink.2
I will try to mount the fall off and re-align the other one and try the no signal on the pan/waterfall.Yes that is what I thought about the image/email I will put it on my open ticket.0
Juan and all. As one of the first to experience this, My flex 6600-M worked just fine with the temporary zip ties in place, and subsequently, after installing the PEN, the transceiver is equally just fine. There are very few operators who put transceivers through the heavy use I do, I just used the 6600-M in a major contest effort over the weekend (along with a PGXL). both worked flawlessly under heavy and continuous use. Keep calm.. carry on.. install the PEN when it comes in... if you need to zip tie in the interim.. no worries. just be careful of the ADC boards, particularly the small transformers and SMT parts.. if you are not comfortable yourself you can always reach out to an elmer with experience with these types of issues...1
I did some fairly used of my 6600 as I was and still astonish of what a Flex can do, that with the adhesive of the heat sinks issues, well and I have the results. I will secure them and report back, thanks.
No problema y buenas suerte1
Gracias Chris !
So put heat sink 1 on chip and tie wrap, re-align heat sink 2 and tie wrap as well.SmartSDR is back receiving !!!
Now anxious waiting for PEN package to arrive to make the proper replacements.0 -
That will work just fine until the new heat sinks arrive.1
Great and massive Thank You for all the support !!!
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
