New version of Smart preinstalled on Maestro
IZ2ODM
Hello guys,
a simple question ; In case of buying of Maestro (that -of course- would have last release version software) , I have forced to pay anyway for 2.2 version to install on Flex or not?
73 IZ2ODM
Roberto
73 IZ2ODM
Roberto
Short answer: Yes.
Your Masestro should ship with latest software, I don't think you will need to pay for the software. That is for people moving from V1.**** an optional upgrade cost.0
Thank for both replies .It seems not so clear.....0
Do you have version 2 software on your Flex now? If so you will not have to pay. If not you will have to pay to upgrade the Flex radio to version 2.
.0 -
The radio has the software license. The Maestro does NOT check the s/w license.1
The licence is with the radio, if you have V2 your good to go0
At the moment I just have flex 6500 with 1.11.12 ; No Maestro. Should I buy version 2 or it will be vers.2 on maestro embedded?0
You will need to purchase the upgrade for your Flex radio. The new Maestro will not upgrade your Flex radio.
Bill said it, if you have V2 on your Flexradio 6xxx then Maestro upgrade is free of course. If you do not have V2 on your Flexradio 6xxx, the Maestro upgrade is still free but it won't work with your Flexradio 6xxx. Versions must match.
Your new Maestro will work with either version.
The radio and Maestro must be on the same version witch ever version that may be.
The firmware versions must match.0 -
The Maestro will work ? I guess that depends on your definition of work. If your connecting to your radio or remotely to someone else's radio, the Maestro version must match the radio you are connecting to.0
Yes, to get Version 2 features Version 2 must be on the radio.
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 191 FLEX-8000 Signature Series
- 913 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 956 Third-Party Software
