V2.2.8 Maestro Issue
Ron
Loaded V2.2.8 this week Monday 5/21 and all worked as it should. I remote from different location at my Shop/Office (same ISP but different accounts). Tried using Maestro today but cannot get it to work. I can remote into my home PC and can start up SmartSDR and all works fine. When I get to the login screen on the Maestro I can disconnect the PC at home via SmartLink and select my Flex-6500. I can select the FW version but I get the following
Maestro can not load hardware
I get the following error
This means one of two things; either charge your battery or Maestro needs a better internet signal. Too many wifi signals, weak wifi connection.1
Yup, dying battery @ <1%, good call. That is what I get for leaving the wall power supply at home0
My Polanfo 12000 mAh is my favorite battery so far (run time, price, it fits ) The new Polanfo is 20,000mAh (even better specs) but it is $3x ha, ha.0
GETIHU is $19.99 but 3.15 inch wide.0
What are the physical dimensions of the new Palano power bank? Will it actually fit inside the Maestro? Info not available on Amazon listing. Have two units now that work fine but won't fit inside the cavity without forcing it, something I won't do. Someone else asked Flex if they offered a replacement cover so the could drill a suitable size hole in it to pass a USB extension through it but never did see a Flex response.
Ian VA3QT0 -
Here is what I am using that fits nicely in the Maestro it is 5.3 x 0.5 x 2.9 inches
https://www.amazon.com/gp/product/B01EHKNKPK/ref=oh_aui_detailpage_o02_s01?ie=UTF8&psc=1
Comes up as 'not available'
Ian VA3QT0 -
Just got to do your homework then by searching on Amazon. Most items have product information & product dimension. See the article below for info
https://helpdesk.flexradio.com/hc/en-us/articles/210311883-Suggested-Battery-Packs-for-Maestro
- 636 The Flea Market
- 144 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
