WNB
W8QB
According to the "SmartSDR for Windows" change log, beginning with the version 2.2.7 alpha software, the Wideband Noise Blanker (WNB) "now works properly" for the Flex-6400M. Did this (enhanced?) WNB functionality make it into the the latest official release, v2.2.8 software? I am running v2.2.8 from the front panel of a 6400M but still see no impact whatsoever with pulse-type noise. Have others in this forum seen any improvement when running WNB?
It has worked for me and others. But some noise is complex in nature, and is hard to eliminate.. The WNB has received a lot of praise over the years... Robert
https://community.flexradio.com/flexradio/topics/wnb-wow
I've noticed that in some conditions the WNB reduces band noise enough to make copy noticeably better.
It seemed to work before the 2.2.8 update too, so since this is my first Flex I too am curious what exactly the bugfix in 2.2.8 entailed.
The WNB was not made for pulse type noise, it is for wide band electrical noise, On 40 meters some nights I have electrical noise, about S7. The WNB knocks it out 100%. Without it I would have to turn off and try another night.0
I don't think anything has changed, the fix was likely to do with how it corresponds with the radio controls.0
According to page 42 of the 6000 series User Guide, "The Wideband Noise Blanker (WNB) is used to combat fast rise time PULSE-TYPE noise."0
I've heard that said of the version 1 software, but have not heard much favorable information regarding how WNB has been implemented with version 2.0
Ok, well what ever it says, I just know it is amazing for the noise I have.0
Tim will probably chime in here and comment on this.. I have several radios with NR and NB features.. Some were rated very high in pulse noise elimination,,, Worst radio, Yaesu FT-991, then comes my Yaesu FT-1000mp, followed by my Icom IC-9100, then my Icom R8600, ranking a 2 up to a 8,, then the Flex 6600M at a 10!! As Bill stated above, it can make what is a near impossible QSO turn into a pleasant experience.
Robert0 -
I'm glad you've had better results. The noise blanker works fine on my (IC-7300) back up radio, although as noted, I have not had any success with WNB on a 6400M running v2.2.8.0
OH, keep in mind that the Flex radios have a real time TRUE Spectrum Analyzer,, This gives you the ability to dig deep into the spectrum and actually show what the noise is, wide band, or some pulse type.. I have not had my radio long enough to compare it to my HP spectrum Analyzer,, but I bet it will hold its own in many field type tests. The Flex radio is more then a ham transceiver, it has attributes that could be considered Test Equipment..
For Example,, I have a Icom IC-R8600 DC-3GHz Receiver-Scanner.. So what I have done is plug ny Cable TV line into the radio.. Very Interesting Spectrum display of QAM carriers, OFDM/200MHz spectrum for Docsis 3.1, and More.. So I baselined all my RF carriers after the local cable company swept and balanced the lines from the Fiber Optic Node up to my home.. I can now go back check if something changes.. Before I did this with the HP analyzer, but it is Big and heavy for some basic and simple testing..
W8QB - the WNB fix you are referring to is we identified a defect where the WNB was not working properly for the 6400s. It has been fixed. If you do not have well correlated wideband noise, the WNB will not be effective on the noise you are trying to mitigate.0
From page 40 of the user guide,
Impulse noise is a category of noise that includes almost instantaneous impulse-like sharp sounds generated by voltage spikes from arcing power lines...
Traditionally, “noise blankers” have been utilized to mitigate this type of impulse noise.
--end excerpt--
Therefore, the 6400M's "noise blanker" (inclusive of WNB function) should be an effective tool for combatting noise associated with power lines, correct?
My experience has been:
WNB takes out some broadbanded noise or hash that may exist more so in the lower bands than upper. the NB or noise blanker takes out the more Pulse like noises you seem to be referring to. The problem with that one is that the strong signals will be distorted for a few seconds before straightening out. A setting in my case of no more than a 4, seems to work real well for some of the Pulse type noises. The NR will reduce most all noise, including the signals you want to hear but
reduces background noise enough to help with most weak signals.
Correct, WNB is Great for combating power line type noise, brush motor noise
73 Mike0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
