new heat sink
Don w2xb
Just wondering if there is any info on the new heat sink for the 6400 and 6600 rigs?
Keeping and eye on temps and turning rig off after operating.
Don...w2xb...
Don...w2xb...
Don,, I think the heat sink is fine, it is the glue that holds the heat sink to the chip itself that is at fault.. Seems like a simple do it yourself fix, Flex send you the parts... I just installed a UX-9100 1.2GHz option in my Icom IC-9100 All mode Satellite defined radio.. Talk about complexity!!! I would think a heat sink is a simple thing to do for 95% of the Flex community who needs to do this rather then sending it back to the factory,,, but that is just me... No fault of Flex, their supplier let them down.. Just had both Airbags changed on my daughters Honda.. Talk about an expensive recall!!!
Robert0 -
The PEN kit is an easy install. It takes more time to remove the 14 Torx screws than to do the replacement. When I did mine, the original heat sink was still firmly in place even though the 6400 has been running 24//7 since January.0
Rick how hard was it to remove the one installed? Use your hand and it gently pulls off or??0
I would like to know where this heat sink is located in the radio. A picture maybe ? Would like know when I am going to get the kit ?
I have never seen the inside of a 6400 or 6600M radio.. I can only imagine what it looks like!! :-)
The heat sink is located on the ADC board. When you get the PEN kit, the included instrucitons (with photos) make it all plain. In my case, I needed to use a pair of needle-nose pliers to remove the original sink as it had not loosened at all. I've heard of others who found them lying loose, or easily removable by hand, but this was not the case with my radio. The new heat sink attaches on the OPPOSITE side of the board from the original, something I missed on my first quick reading of the instructions, something I'm all too prone to do...lol.0
Rick did you happen to notice what the adc chip number was?0
Probably a 12AT7.0
Sorry, but no. I had no reason to inspect it that closely, I'm a software guy, and don't pay much attention to the hardware details as they're not something I'd normally be dealing with on a personal level. Changing out the heatsink is as close as I'll ever get to being a hardware tech.. ;-)
Isn't that a tube number?0
OH, Yes It IS!! :-) Cant fool any of these Flex Experts!!! :-)
Just saw the PEN kit install video for the 6400/6600 put on the YouTube channel. I've never seen a heatsink placed on the back of a board. Can someone explain how this works? Also why do you have to remove the original heatsink?
Interesting Video. You can definitely see that the new heat sink is twice the size of the old one.. In most cases the ADC Chip was Glued to the PC board BEFORE it went through the Solder Flow Machine.. The Heat Sink is pulling any heat that is being transferred to the PC Board... I think Flex can validate my claim.. Not a common thing to do, but it has been done before many times with CATV type equipment, the stuff that hangs up in the Air on your telephone poles..
Robert0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
