6400 DOESN'T TRANSMIT IN FM/NFM WITH EITHER + OR - OFFSET WORKS IN SIMPLEX AND OTHER MODES.
Bill
My first Flex radio. Loving it except - The 6400 doesn't transmit in either FM or NFM with either + or - offset. It does transmit in simplex FM & NFM modes and other modes (USB, CW). I tried cold boot several times (6400 OFF, PS OFF & disconnected for more than a minute, reconnect, PS ON, 6400 ON). same result. NO XMIT! Running SmartSDR 2.2.8.
Check your offset frequency. You may be trying to transmit out-of-band if it set to an incorrect value.
Craig, KØCF
Thanks. That was it. -500 MHz instead of 500 KHz.0
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
