How can I change the DAX Control Panel (v2.2.8) to the second FLEX radio?
Rudy HB9MHB
I have two FLEX radios (6700 and 6500, both V2 License) on my Network. The first radio is connected to the Maestro, and now when I open SmartSDR 2.2.8 on my computer the DAX Control Panel connects to the first radio, even when I choose the second radio on SmartSDR. The CAT Control Panel is correct and shows me the second radio. What I am doing wrong? Thanks a lot
DAX does not have the radio chooser capability.
Without a filter file, if both radios are powered up when DAX is started, it will connect to the first one it hears on the network. You can use a filter file to only connect to a particular radio. It is much easier to make sure that the radio you do not want to connect to is powered off, Start DAX have it connect to the proper radio and then power up the other radio.
https://helpdesk.flexradio.com/hc/en-us/articles/202549169-How-to-prevent-multiple-FLEX-6000s-from-s...1 -
Thanks Tim for the infos, the filter file works fine
Rudy HB9MHB
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
