DAX control panel - TX gain setting when operating FT8
edited January 2020 in FLEX-6000 Signature Series
On FT8 and other digital modes the DAX control panel's TX gain slider can be set anywhere between 0-100.  Where should the TX slider be set for optimal results?
Welcome!
  • Member ✭✭✭
    edited May 2018
    Set it so that the Mike Meter does not peak into red
  • Member ✭✭
    edited April 2019
    Thanks Howard!
  • Member ✭✭
    edited December 2019
    Yes, keep microphone peak meter from reaching the red (0dB). I set the processor to DX. Now the Flex is using CESSB which all but guarantees you won't splatter ( and a 2.5dB gain in your signal helps keep TX power lower).
  • Member ✭✭✭
    edited May 2018
    Digital modes should not use any processing at all, so only use DX setting with phone, and always set audio input gain to prevent clipping and distortion no matter the mode.
  • Member ✭✭
    edited May 2018
    Agree. Under mode I use DIGU which I believe also disables the processor and the EQ.
  • Member ✭✭✭
    edited May 2018
    Definitely use DIGU
    That automatically disables EQ and Compression
    Never use any form of EQ or Compression with Digital Modes
  • Administrator, FlexRadio Employee admin
    edited May 2018
    Actually, it is best to peak about -3 dB so you have some headroom on crowded bands with lots of signals (or Howard running 15KW)
    edited May 2018
    Digital modes do NOT use any audio signal processing.
