Still Having DAX Problems (after Windows Updates)
Jerry W2TXB
Jerry W2TXB Member ✭✭
edited May 2018 in SmartSDR for Windows
After checking the things mentioned by Neal ( https://community.flexradio.com/flexradio/topics/most-common-fix-for-dax-driver-errors-in-windows-spring-update-1803-you-can-do-this ) and finding all Audio Inputs and Outputs intact, along with more than six Uninstall/Re-installs of the DAX drivers as suggested here prior to that, I am still unable to use DAX to operate digital modes. Using the latest SSDR before and after  both of the recent Windows 10 (64-bit/Pro) updates, I am finding the last step (#17... SmartSDR_MICAUDIO_DAX_install.bat) failing every time. Here is what I get:
C:Program FilesFlexRadio
SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>SmartSDR_MICAUDIO_DAX_install.bat
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>REM Install the MIC Audio DAX driver
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>REM 64 bit version
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>REM ** Must be run with elevated Administrator rights **
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>md "C:UsersW2TXBAppDataRoamingFlexRadio SystemsInstLogs"
A subdirectory or file C:UsersW2TXBAppDataRoamingFlexRadio SystemsInstLogs already exists.
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>regedit /s RemoveRegistryEntries.reg
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>regedit /s .MICAUDIO_DAX.reg
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>regedit /s .MICAUDIO_DAXService.reg
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>copy /v /y .SmartSDR_MICAUDIO_DAX.inf C:WINDOWSinf
1 file(s) copied.
C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAX>.wdreg -inf SmartSDR_MICAUDIO_DAX.inf -log "C:UsersW2TXBAppDataRoamingFlexRadio SystemsInstLogsSmartSDR_MICAUDIO_DAX.txt" install
WDREG utility v10.40. Build Oct 17 2011 12:38:06
Processing HWID FlexRadioSystems_DAX_MICAudio
Installing a signed driver package for FlexRadioSystems_DAX_MICAudio
Error: Failed to install the INF file (C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAXSmartSDR_MICAUDIO_DAX.inf)
LOG ok: 1, ENTER: DriverPackageInstallA
LOG ok: 1, ENTER: DriverPackageInstallW
LOG ok: 1, Looking for Model Section [DevSection.NTamd64]...
LOG ok: 1, Installing INF file 'C:Program FilesFlexRadio SystemsSmartSDR v2.1.3364-bit DriversMICAudio_DAXSmartSDR_MICAUDIO_DAX.inf' (Plug and Play).
LOG INFO(1): error 3, Could not open file C:WINDOWSSystem32DriverStoreFileRepositorysmartsdr_micaudio_dax.inf_amd64_97c04506f914c4dbsmartsdr_micaudio_dax.inf.
LOG ERROR(3): error 3ee, PnP Install failed.
LOG ok: 1, Attempting to rollback ...
LOG ok: 1, No devices to rollback
LOG ok: 1, RETURN: DriverPackageInstallW (0x3EE)
LOG ok: 1, RETURN: DriverPackageInstallA (0x3EE)
difx_install_preinstall_inf: err 3ee, last event 3, last error 3ee. UNKNOWN
Error: Failed trying to install the driver
Any ideas of what to try next? Although I have even uninstalled SSDR, CAT/VSP, and DAX, and then reinstalled them (no joy), is there a way to completely remove all traces of them (short of wiping the HD and then reinstalling Windows and everything else)?
Also, will the next release of SSDR (2.2.__) fix the problem, once and for all (I can wait)?
Thanks in advance.
  • Neal - K3NC
    Neal - K3NC Inactive Employee ✭✭
    edited May 2018
    Jerry
    Create a trouble ticket and I will be happy to connect and see if I can clean this out!
  • Jerry W2TXB
    edited May 2018
    Neal,
    I started a Help Desk request yesterday, and then worked a bit more with it today. Here is an update:
    Following a suggestion from a guy who lives fairly close on another web forum (referring to another ham's Win-10 messing up RigBlaster and other digital mode drivers), I decided to try changing one of my privacy settings (after another reboot and still no success)... the setting is under Microphone Privacy, and it was switched off (I have no mic connected to the PC running the Flex). Apparently, the Windows 10 definition of "Microphone" differs somewhat from the way the rest of us see it. Anyway, I switched it to "On" and rebooted the PC. Tested with FLDigi and all symptoms have been resolved, at least for now. I will try several more contacts to ensure the results are going to last. How this "fix" (workaround?) has any connection to the "MICAUDIO_DAX_install.bat" errors that were encountered, I do not know... may have to chalk it up to "It's Microsoft and all bets are off". ;)
    Thanks again; I will update as necessary, but at least for the time being, I will not mess with success. It is hoped that, by posting this update that I did not jinx everything. ;)image
