wireless headphones for flex 6400M.
KB4OIF
OK. Is there a wireless headphone that can be paired with the 6400M. I her folks talking about it but have not been able to find info.
You can purchase a Bluetooth device which plugs into the audio output with a 1/8" trs plug and when you turn it on it will pair with your choice of wireless bluetooh headphones and transmit the audio to your headset. May not be interference free when you transmit especially if you use high power so beware and try it with your headset away from your ears till you know there is no interference.
I have one I purchased for $10 on ebay and used with my sony Bluetooth headset when I had the Icom 7300 and it worked fine without interference either but I was only running 100 watts then.
YMMV.
My experience is that Bluetooth has too much latency for use with CW.0
I use a Jabra on my flex's works well. Hooks up where your hand mike does.
I looked on the Jobra site, I don't see that thing, what is it? I gather it pairs with your headset? Got a model number???
Have you tried with amp on and CW??
Peter0 -
Model 9350 KT9D makes these up if you wont more info he is OK on QRZ
They work fine with amp and cw.
Try a pair of low-latency headphones and transmitter these are mainly used by people who want to broadcast audio and watch video that should work really well with CW.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
