6600 Straight key
Ned K1NJ
Ned K1NJ Member ✭✭
edited December 2018 in FLEX-6000 Signature Series
   On page 21 section 7.4 of the 6400/6600 hardware reference manual there are
illustrations of keying connection jacks.  It looks as though a straight key will key
dots only when used as shown.  Is this correct or is some information missing?
              Ned,  K1NJ
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited January 2019
    You need to turn off the internal keyer.  Then it becomes a straight key input.
  • K0FLY
    K0FLY Member ✭✭✭
    Duane has it.  On the P/CW panel of the SSDR control panel de- select the "IAMBIC" button (grayed out) to use an external keyer or straight key.   The trs connector "TIP" does double duty.
    Gayle K0FLY
  • Ned K1NJ
    Ned K1NJ Member ✭✭
    edited May 2018
        Thank you,
                            Ned
