Any pictures of the 6400 with handle and rack mount options?
Ron W4RDM
Would like to see on a radio before I order?
I did not know there was such an option? Where did you see this?
did you mist the email ;-)
Dear Customer,
The new radios are just around the corner – here is your final invoice!
If you would like to add any of the following accessories or an extended warranty to your order, please let us know and we will update your invoice.
Options are as follows:
• ATU - $299
• GPSDO - $699
• Extended Transmit (MARS) - $399 (MARS Credentials Required)
• Handle Kit - $75
• Rack Mount Kit - $99
• Dust Cover (for front face of M models and Maestro) - $49.99
• Maestro - $1199
2 Year Extended Warranty (http://www.flexradio.com/support/extended-warranty-program/):
• FLEX-6400 - $250
• FLEX-6400M - $350
• FLEX-6600 - $400
• FLEX-6600M - $500
Cables:
• 8 pin foster to 1/8in (3.5mm) TRS (ACC-8P-TRS) - $34.99
• 4 pin XLR to 1/8in (3.5mm) TRS (ACC-4PXLR-TRS) - $39.99
• 3 pin XLR to 1/8in (3.5mm) TRS (ACC-CX0076) - $23.99
• 3 pin XLR to 1/4in (6.35mm) Balanced TRS for FLEX-6600(M) (ACC-STX-310F) - $23.99
(Note: if adding options please do not complete payment until your order has been updated. Please notify us and we will send you a new invoice with the adjusted totals.)
but were it start to be confusing is on invoice it wrote ..
6000Series:6400/6600-RKMT
FlexSeries RackMount Kit for FLEX-6500,
FLEX-6700 and FLEX-6700R
so did it same handel that for old radio , i guest not since not same radio height ??0 -
Apparently, I did
So still not sure about the M radios having handle kits either.
I guess pictures are in order !
Pictures would be excellent for the options that are physical. It's hard to make a judgement call on these without being able to see what you're purchasing.1
I too would like to see the rack kit before I BUY.
Will you be able to use both at the same time like the 63/65/6700?
Will there be rack ears and a rack handle kit like the prior radios?0 -
still no picture or official comment ? or even a computer rendering ?0
The item is not currently available.0
Available to buy right? When you are invoiced that is.
hope that flex will not delay my order because of that "available soon" handle kit !!!
have already to make this week end Contest (January VHF) whit less that optimum setup and for sure now will miss the Bouvet EME window ....
I am sure if the handles are not ready, they will ship them later.0
Marc - it will not delay your order being fulfilled.0
How many rack spaces (?U) will the 6400 take with the rack mounts?0
4U?
I did find this picture of the 6600 with a rack mount. I assume it would look the same.
I just measured my 6400 (not int a rack) and it will take up 4U even though the rack mount brackets are about an inch shorter. The bottom of the enclosure has that section that drops down and make the entire height 4U.0
Thanks ! I'm using an 8U cabinet, and was wondering if I'd have enough space for the other items. 4U will leave me enough room. Good news.1
Hi Tim any dead line for shipping the bracket ?0
That is a Sales question. Send Michael an email inquiring about their availability.0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
