Hardware ALC not persisting
W8QB
For the 6400M, under the menu's transmit tab there is the option of setting "Hardware ALC" to ENABLED. This setting should persist when changing between bands, page 53 of the user guide indicates. Many people prefer not to use Hardware ALC, but for those who do want "ENABLED" to persist, what is the solution?
Did you try it in a transmit profile as well? Page 55 says it can be saved in the transmit profile also. Just curious.0
Hi Wayne, thank you for this suggestion! Leveraging the transmit profile to enable Hardware ALC was a successful workaround for my radio. But for this to work, I found it was necessary to toggle "Enable" and then re-save the transmit profile on each individual band, for a total of 11 re-saved profiles (160 meters through 6 meters). Hopefully a future software update will allow the operator to set Enable just once such resulting in a setting that persists when changing bands. The user guide clearly indicates that the setting for ALC Hardware is meant to persist, but in my experience running version 2.1.33, it does not persist.0
Actually I set my transmit profiles band independant but for ssb 90w or ssb 30w for either amp or no amp operation. I set the global profiles for the band. That way I choose the band by global profile then just load the transmit profile for the power i want then i can just crank the power up or down whether i use the amp or not and dont have to really load a different transmit profile i just make sure the tx enable is set on all the transmit profiles. Many ways to do it just have to find the one that is closest to the way you want to operate.0
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
