Water fall
DonE
DonE Member ✭✭
When i transmit i see Horizontal lines on the water fall, what would be causing that and is it harming anything?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    edited July 2019
    Hi Don.. this is totally normal.  Nothing is being harmed.
  • Steve - K6SRS
    Steve - K6SRS Member ✭✭
    edited May 2019
    Sometimes the Electron Bucket gets too full and overflows. That puts a line of electrons across your waterfall. Or something like that ...
  • DonE
    DonE Member ✭✭
    edited May 2018
    Thanks fellows just got my 6400 on the air, appreciate all the help.
  • Tim - W4TME
    edited April 2018
    We blank the waterfall on TX because on transmit, the signal level received by the receiver is much higher than when receiving off of your antenna and it takes a while for the auto black level to normalize, so it screws up the waterfall intensity display for several seconds after transitioning from TX to RX.
