CW switching from QSK to Semi-Break-in
Steven Linley
Where can I read about switching to CW Semi-Break-in vs what the Maestro is now (CW QSK).
Also where can I read about how to adjust delay times. My Amp has an output relay, I don't want it switching on every Dit. What is the best way to keep the amp in TX mode during letters and/or words but drop out between words (instead of between Dits as it is now).
Steven,
In the P/CW panel on the right side of the screen (of my no-M 6600), changed Delay from zero to something like 100-200ms. If not enough delay for your liking, make it higher--adjustable up to two seconds. I have mine set for 200ms, generally operate at about 25wpm, and this feels comfortable for me.0 -
Thanks Jerry, maybe this is something I must do from SmartSDR. Using the Maestro I go to
Menu>Phone/CW and I can select Breakin: Enabled or Disabled. OK just tried it and when Disabled I control the TX mode with MOX or my foot switch. That works for now.
Thank you
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
