How do you run split with FT 8?
W2PP
Member ✭✭✭
I can't figure out how to run split with the 6700 using FT8. I'm sure it can be done. Any help appreciated.
Peter
Peter
It’s all done in the WSJT software... just click on the Hold TX Freq. on the monitor screen now click on whatever station you want to receive and you are working split.... has nothing to do with the 67001
Split as in split operation to shift the TX passband? Use “fake it.”0
ah, OK, got it. Ria what is "fake it"
Peter0 -
Fake It shifts the transceivers frequency during transmit to keep the transmitted signal within the 1000 to 2000 Hz bandpass. Example, you are transmitting on 2215, the transmit freq would whift 1 KHz higher and the radio would actually be transmitting 1215 Hz. This is more important with older transmitters which have narrow transmit passband. Dave wo2x1
Ok is Fake It an app?0
no. it is a setting in the radio setup tab in WSJT-X.
Here is a screenshot of my 6600 setup.
In my example I created a new CAT TCP port 5004.
OK, i'll take a look at this. THanks0
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 905 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 713 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 935 Third-Party Software
