Digital (DAX) Separate Power Level?
David Salomon
Is it possible to set a different power level for data coming from a DAX channel vs the power level set for TX? For operating digital and voice, I'd like to be able to automatically set a lower power level when transmitting from a DAX channel, then automatically revert to the previous, higher power level when keying the mic.
Is this possible currently in SSDR / 6600M?
73 - David, AG4F
73 - David, AG4F
No, but your question suggests that you may not be using the DAX TX channel in the recommended way.
As I understand it (and as I use it), the transmit power level when sending audio data from the DAX TX channel should be set to 100%. I believe there is a white paper in the knowledge base to this effect. Control the transmit power level using the DAX TX channel gain.
If you normally transmit voice at 100%, or some lesser level, you should be able to use that level for both SSB and Digital, and vary the actual digital transmit power level with the DAX TX channel gain.
That's what I do, for better or worse.
That's a good idea (why didn't I think of that
. Now that you mentioned it, I do recall reading that. I'll try to reduce the TX Gain in DAX to see if I can achieve what I'm trying to do. My issue is that I'm using a T2FD for both voice and data. The terminating resistor is rated at 1400 watts PEP, but only 350 continuous, hence my need to ensure that I'm not sending data at high power. I don't want to watch that resistor catch fire.
73 - David, AG4F0 -
Set up your Profiles for each Mode with different power output levels that suits your needs.
Bret
WX7Y
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
