Loads OK, But will not "START" using Flex 3000 PowerSDR
K5PZ
PowerSDR v2.7.2 boots and runs as long as it's in STOP. But Hitting the START button produces a pop-up window "PortAudio Error: -9998 Invalid number of channels." Then clicking OK in the box, a new box pops up saying "Invalid stream pointer". Can someone help? Running Windows 10 Pro.
Did you search the forum to see what Tim said to others on this. I recall something about your problem but do not remember what was done. Look around and see what you may learn.0
I also expect you windows had an update and messed with the ports.. you may need to unistall, including all folders and files for PSDR and re install.0
I got that error when I first installed PSDR. Trying to remember what it was. Seems like it was something with the FireWire card. Make sure you have the correct drivers installed .0
Yes, I've done searchs but no joy finding this. A clue is that it was working after I installed PowerSDR the first time (a day ago). Then I wanted to make Remote Desktop work. When I was on the remote computer, I couldn't START PowerSDR either. But when I went back to the local computer, I had the same problem as the remote computer. I couldn't now START PowerSDR from the local computer without getting the error messages.0
Another clue.....if i DON'T enable both VAC 1 AND VAC 2 , then I can START PowerSDR. But I hear no audio at all from the computer. Also, interestingly, on the Audio Table of Setup, the VAC Input pull down menu is grey'd out. The Output pull down menu lets me choose Primary Sound Driver, Speakers, or Realtek Digital Output. When it was working before (yesterday) I saw items in the VAC Output pull down menu.0
install psdr completely, then re-install and try again. Perhaps remote desktop is grabbing the ports and not letting go.
Make sure that in the PSDR setup that the vac for RX and TX are not reversed.
Pat0 -
Peter, this is an audio problem, no need to reinstall PSDR. Which VAC version are you using with which OS version? I run VAC 4.15.0.7314 with Windows 7 and 10 (64bit) and this is the last version which works well for me. Here is my setup:
Reinstalling VAC and trying the above mentioned version should work.
Also be careful what the Windows audio controller does with your new VAC cables.
Check all settings, then use PSDR VAC 1 to set the cables and VAC 2 for your speaker and Mike.
Oh, and I you run Windows 10, give the VAC folder all permissions!
Alex - DH2ID0 -
Thanks Alex for your posting. I set my VAC up exactly as you've suggested. However, I still seem to have some kind of conflict going on when using Remote Desktop. I'm having trouble with getting the TX audio to work from my remote computer. But at one time (in some configuration I can't reproduce), it worked! So, I just have to find that configuration. More importantly, if I click either VAC1 or VAC2 button on the remote, I immediately get an "unanticipated host error" and the app forces the remoted PowerSDR operation to "OFF". I can power START back up from the remote, but only if both VAC1 and VAC2 are disabled on the remote. Once START works, there is no audio because I can't re-enable either one of the VACs on the remote without it crashing again. I apparently don't have the configuration correct. Can someone who is running Remote Desktop and PowerSDR please help me with the proper configuration. I've trial and error tested configurations until it was totally apparent I have no idea what I'm doing. Anyone?
73, Pete K5PZ
Sorry, Pete, can't help you there, as I don't use Remote Desktop.
Have you seen this video: https://www.youtube.com/watch?v=kVTFjR77xXc
And there is KE9NS's website: https://www.ke9ns.com/flexpage.html#rdp
Look for Remote Desktop on the left side.
FlexRadio has this: http://kc.flexradio.com/KnowledgebaseArticle50503.aspx
Good luck! Vy 73, Alex - DH2ID0 -
Alex,
Thank you for your time to reply and forward this info to me.
The current status of my journey is that I now have the Remote Desktop working except for a couple of issues. I have a high TX noise added to my voice.
Watching closely the KE9NS video, he too seems to have a high background noise level in his TX audio when using the remote PC's mic audio. When I run the mic gain up to get full RF output during a Remote session, the background noise is excessive (it's not from my quiet room ambient noise). I hope there is some setting combination that mitagates this.
BTW, in order to get Remote Desktop to work at all, I have to make sure the PowerSDR app is OFF on the local PC. I then access the local PC with the Remote PC's Local Resource setting on "Play on Remote Computer". I initiate PowerSDR on the local computer, then close Remote Desktop. Then I change my Local Resource setting on the Remote PC to "Play on this computer" and access the local computer again. Presto, I have two way audio connection now, but with the added TX audio noise. As I said, looks like KE9NS has the same issue if you watch his video closely (see that his TX spectrum plot is also very high when he's not talking).
That being said, I'm extremely interested in the TEAMVIEWER app. I've used Teamviewer in my business and it worked great. I'm thinking it might work here too. However, I just paid $99 to upgrade my Windows to 10 PRO so I could use Remote Desktop and I'd like to run that to ground before giving up on it.
New Issue: I connected my CW Paddle to the front of the Flex 3000. I can't use it!!! The sidetone is NOT sync'd with the paddle. The sidetone is heard waaaaay long after I touch the paddle. I can't send CW that way. Who can? I searched this site with all kinds of search words, but I didn't find any solution for getting the sidetone sync'd to the paddle. Any idea?
Best 73,
Pete K5PZ
Trying not to be a newby PIA.0 -
Update: I found a posting here on the community suggesting that I disable VAC and use the headphone jack on the front panel of the 3000 when in CW mode. It worked perfectly. I now can use my paddle. Sorry for all of the bandwidth. I am still interested in finding out if anyone knows about the background noise in the audio when using Remote Desktop. TU de K5PZ
I'm glad you found that, Pete :-) My remoting is done with the Flex-6500, so I can't help you there. 73, Alex - DH2ID0
Pete,
Your original issue was with the Port Audio error was that you did not have a working sound card in you computer or the sound mapper was missing .. This will issue of the noise in the Remote Desktop was that when using VAC button to reroute the Sounds,, these are line levels from the radio VAC levels are on the front of the PowerSDR console (version 2.7.2) not sure what Darren has done with them ... There are lots of ways to misconfigure / reconfigure .. If you want your PowerSDR volumes to work correctly , then run a stereo TRX from the power speaker output to the sound card input , and then the line out of the sound card back to the radio .leave the VAC settings out of it ... then you can use the VAC for you digital modes as it was intended.. Food for thought.
Hi Dudley,
Happy Easter/April 1 day:
If I understand you correctly, you're telling me that I did the wrong thing by running an stereo audio cable from the Flex 3000's front panel headphone jack over to my powered speakers. I should have run that cable to the sound card input (the sound card's microphone jack?) instead of to my powered speakers? Then I should make a RJ-45 cable for the front panel of Flex 3000 to run the mic connection over to the sound card output? If I do that, where do I connect my local microphone?
Any idea on why my RF output power is only 80W - 90W on some bands and over 100W on 15M?
Best 73,
Pete
- 250 Community Topics
- 489 The Flea Market
- 7.4K Software
- 331 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 779 Maestro
- 42 FlexControl
- 731 Genius Products
- 254 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 119 Contesting
- 585 Peripherals & Station Integration
- 116 Amateur Radio Interests
- 810 Third-Party Software
